Текущее время: 14 окт 2026, 10:06
Совет - как правильно защитить машину от УГОНА
Автомобильная сигнализация со встроенной видеокамерой = 429$
Сообщение Диксон » 20 окт 2006, 21:46
Всем тем кому личная машина дороже КАСКО, предлагается
очередная необычная автосигнализация со встроенной цветной
видеокамерой с ночным режимом и ЦВЕТНЫМ LCD монитором
встроенным в брелок управления.
Scytek VisionGuard 8000 2 Way Camera
Alarm With Remote Start & Color Remote = 429 $
WORLDS FIRST: AUTOMOTIVE SECURITY WITH A
BUILT-IN REMOTE CONTROL CAMERA AND NIGHTVISON
ScyTek electronics Inc. a leading manufacturer
and supplier of automotive security and remote
engine start systems, introducing: the first
in the world Camera Alarm Remote Start System.
The patented built-in camera with night vision
technology automatically snaps and stores full
color pictures of any attempted entry violation.
The systems’ two way paging remote control
receives and displays the stored pictures in
full color. In addition, the remote control can
snap and receive pictures at any time.
*New Compact Color Camera/Antenna with Night Vision
*Automatic picture capture upon security violation
*Selective picture capture through the remote
*Store and recall up to ten discrete images on the LCD remote.
*One Carbon Fiber 2-Way True Color Picture Remote control.
*One Carbon Fiber Slick 5-Button Remote *With Super Bright Blue LED
*Built-In Parking-Light Relay Programmable (+/-)
*One 5 button code hopping remote control Sleek Carbon Fiber with
*Plug In LED and Override Switch
*Remote Start Tachless Mode using Adaptive Digital Signal Processing
-compatible with all vehicles
*Remote Start Tach Monitor
*Starter Interrupt Output
*Dual stage Electronic Impact sensor
*Power door lock control
*Trunk Release
*Parking Light Flasher programmable polarity
*Courtesy Light Control
*Anti-grind Option
*Gas or Diesel compatibility
*Cold Start timer
*Selectable Engine Run Time
*Turbo Timer (adjustable)
*Smart Network Port
*Easy programming Via your PC, Pocket PC or Valet Switch
and Remote Transmitter
*Lifetime Warranty
Диксон
от спутника накидыват просто металлическю сеточку на машину
Сообщение cells » 30 окт 2006, 19:28
boris55 писал(а):
Olaf писал(а): Потому как в начале им нужно будет сломать сигнализацию, потом имобилайзер, потом блокиратор коробки передач (у меня стоит он), а тронуться с места все равно не смогут :)
:lol: :lol: :lol:
А если еще проколоть все 4 колеса и отнести домой сиденья-то точно никто угонять не станет-не все же так запасливы?
У друга Лендкрузер-Прадо со спутниковой сигнализацией С ДАЧИ угнали.Он 80-летие матушки отмечал(дача обычная-с забором из сетки).Легли спать-проснулись-нет машины!.Замок с забора откусили и через задние ворота дачного поселка выкатили тихо.Погрузили на эвакуатор....Сторож на основных воротах и не проснулся.
А в "спутниковой охранке"на телефонный звонок ответили:"Да,что-то мы не видим Ваш авто".... :roll:
cells
Заметно снижает ремонтопригодность Логана в случае чего
Сообщение cells » 30 окт 2006, 19:33
IPM писал(а):
Dimitri Pavlov писал(а): Все сделано так, что при замене любого компонента в системе ЭБУ впрыска или блока салона на штатные от других машин двигатель не запустить. .
cells
Сообщение Vadim64 » 30 окт 2006, 22:51
Хочу поделиться одной доработкой к обычной сигналке, которую мы с другом придумали, когда «милые» детки кинули кирпичиком в его машину (авто паркуется на улице возле дома).
Все знают, что если у «мобилы» нажать кнопку ВЫЗОВ, то появится журнал звонков, второе нажатие включает вызов последнего номера из списка, дальнейшее нажатие на кнопку ни к чему не приведет, вызов будет продолжаться.
При срабатывании сигналки обычно мигают габариты.
По сему, был взят старый мобильный телефон, разобран и параллельно контактам кнопки «вызов» были припаяны пара проводов и выведены за пределы телефона.
Взяли, обычное автомобильное реле с нормально-разомкнутыми контактами и параллельно габаритам включили обмотку реле, провода от кнопки «вызов» присоединили к контактам реле. Теперь, при срабатывании сигнализации телефон начинает звонить хозяину машины. Конструкция успешно работает почти год. Да, еще сим-карта должна быть новой, а то некоторые модели телефонов ставят входящий в первую строчку журнала, тогда телефон начнет звонить «дяде».
Vadim64
Сообщение Dimitri Pavlov » 31 окт 2006, 21:08
Vadim64 писал(а):Хочу поделиться одной доработкой к обычной сигналке, которую мы с другом придумали, когда «милые» детки кинули кирпичиком в его машину (авто паркуется на улице возле дома).
По сему, был взят старый мобильный телефон, разобран и параллельно контактам кнопки «вызов» были припаяны пара .
А что, идея-то хорошая вообще-то. И значительно дешевле чем ставить сигналку с пейджером и дальность соответственно хорошая. Вот только подзаряжать телефон от чего? Постоянно держать в прикуривателе? А я и подключить сам не могу: машина на гарантии...
Dimitri Pavlov
Откуда: Россия, г. Астрахань, Logan Expression 1.4 + A/C
Сообщение Vadim64 » 31 окт 2006, 21:34
Телефон у друга заряжается от прикуривателя, а подключиться к габаритам, я думаю можно на панели предохранителей, и перед поездкой в сервис все быстро демонтировать.
Vadim64
Сообщение мизгирь » 01 ноя 2006, 12:39
А ещё проще крокодилы на аккумулятор накинуть.
мизгирь
Сообщение Дисыч » 01 ноя 2006, 13:42
Афигеть :shock: Да если я сделаю все ЭТО со своей машиной то обязательно застрахуюсь по КАСКО! Такое добро терять! Или проще сразу КАСКУ.
Хотя у меня был знакомый кулибин, что бы завести его ГАЗон (самосвал) нужно было:
-вывернуть колеса до упора вправо,
-отврыть дверь,
-нажать на сигнал,
-выжать тормоз,
и можно заводить!
Дисыч
Сообщение Vadim64 » 01 ноя 2006, 16:37
мизгирь писал(а):А ещё проще крокодилы на аккумулятор накинуть.
Это из какой оперы?
Vadim64
Сообщение мизгирь » 01 ноя 2006, 17:35
Vadim64
Крокодилы - электрические зажимы.
мизгирь
Сообщение Vadim64 » 01 ноя 2006, 20:04
мизгирь писал(а):Vadim64
Ой, спасибо научили, работаю с электроникой, а этого не знал, позор на мою седую голову :( .
Если серьезно, я имел ввиду- к какой теме?
Vadim64
Сообщение Vadim64 » 01 ноя 2006, 20:25
У меня сигналка, установленная сервисом моргает поворотниками, сегодня посморел по проводам, подключили они похоже к авриной кнопке, чтоб не лазить туда проще подключиться к разъему лампы поворотника подоткнув провода снизу и зафиксировать изолентой. Провода затащить в салон можно слева, около педали сцепления рядом с основным жгутом проводов которые идут в салон.
Vadim64
Сообщение мизгирь » 02 ноя 2006, 12:46
Vadim64
Прошу прощения, если обидел. Я не отслеживаю (и не стараюсь запомнить) профессию каждого участника.
Я имел в виду подключение подзарядки телефона. А что ещё так можно сделать? Была, правда идея (не помню где) измерять напряжение на аккумуляторе и при его просадке (открылась дверь - зажглась лампочка) включать сигнализацию, но это скорее теория, чем практическое решение.
P.S. Вопросы надо понятнее ставить. ;)
мизгирь
Сообщение Another Drive » 14 апр 2007, 17:52
Привет всем!
Подскажите официальных установщиков сигнализации
Clifford Matrix 50.5X
в Москве.
Заранее спасибо
Another Drive
Сообщение ZhucK » 14 апр 2007, 18:26
Как на счет отключения привода замков от личинки, чтоб ключом уже двери нельзя было открыть, только сигналкой... Стекла бьют не всегда, проще личинку свернуть шума меньше, если все же начнут бить, то (при отключении еще и ручного механизма блокировки)через окно залазить придется, а в нутри при закрытых дверях сильно не развернешься....
Если все это будет происходить ночью в безлюдном месте, то сильно конечо не поможет, а вот при свидетелях вряд ли кто то будет такой камосутрой заниматься, тут даже банально магнитолу не сопрешь...
ZhucK
